WTB 2014-15 Silverado Projector Headlights
I currently have the regular LT non-projector headlights. Anyone looking to sell their headlights? Not really wanting to go aftermarket.
Check your local dealerships. I just picked up a set for $350 that are new OEM takeoffs. They guy who bought the truck wanted Anzo installed.
Who did you talk to at the dealer? Parts guy?
Accessories manager or parts manager if they don't have one.
Sent from my SM-G930V using Tapatalk
Thanks. Did you buy them from the actual dealer, or the manager. Wondering if they get to keep the parts the customers swap out or if they belong to the dealer. I would love to trade a detail for some LTZ lights...
From the manager, but got a written receipt.
Damn! 350 that's a Steal! I might try that option. I saw people were buying some legit aftermarket ones from http://www.1aauto.com/but they have been sold out for a while with no turn around time on when they will get more.
I won't tell you that the deal came with the tail lights too then :P
:wtf::wtf: now your just showing off
I might sell you my eagle eye replicas if interested. I'd just need to swap out my PTM trim for the chrome was all
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
