4l60e problems!
i have a 4l60e (2001) push button 4x4 and the transmission is bad i think. when the transmission is cold it will manually go into all gears but when the trans warms up after a few minutes it looses all gears. is this a bad pump????? Bad converter? i just want to get conformation before i start ripping the transmission apart. Thanks in advance!
The only simple thing to check is the fluid level once it warms up.
This, and condition of fluid. More than likely, trans work is probably in your future.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
