Just wanted to share my project for those who might be interested on doing the conversion. Some might think is a waste and some might actually like it. every body has there own taste and gotta respect that. My truck started as a 2015 silverado black sport edition I think that's what's called. It was wrecked and I had to replace front end so why not upgrade while at it. Here is the result.
From this
To this
Edited by Dbeto54
  • Like 9
Dang I'd hate to see what the cost on this was!! Looks awesome though!!
Thanks, I bought the headlights and taillights really cheap from a local junk yard which were the most expensive parts from dealer ship. It was only about $1,500 more than I would of spend on the '15 front end, so I believe it wasnt that bad.
Damn how did you find heads and tails in a yard so quick?! That's pretty awesome then!!
Yeah got a family friend In the junk yard business. He was able to locate them for me. They werent perfect cosmetically talking but still functional.
That's pretty awesome!! I'd like to have a friend like that lol. I need PTM bumpers lol
I need a lot more pictures and info! What was the total cost? I was so pissed I didn't know about the 16's when I bought my 15 lol
Did you have to have your bcm programmed for the lights being that they have the leds for the drl?!
Oh yeah, more pictures!
I also want to know how you got the drl(ltz) leds to work I want to swap my drl for the ltz LEDs as I have a Lt model and don't have Led.Oh ya almost for congrats,people like you that makes the first jump off the bridge opens all the doors,thanks for sharing.
I know right lol
I will get more pics as soon as I get a chance and will try to write a kinda DIY guide for the headlights
Thanks lol I couldnt find much info on how to do it so I kinda pull the trigger without knowing for sure if it was going to work. DRL just need a NC/NO relay that will switch between DRL and Low Beam mode. I will try to write down a "how to" as soon as I get some free time. Its not hard at all.
Please do I like how the LTZ have the extra leds,didn't know only the LTZ's(maybe high countrys too)had them till I bought my truck.
Damn!!!!! You did a great job... I'm not gonna lie.. I was really looking at the photos to see if it was just another truck.. but looks legit.
Since you have a 2016 I believe you'll only need the headlights and nothing else. The plug is the same maybe just messing with the last 2 wire will do the trick, but I believe the are plug and play. Will need to see a pic of an LT headlight connector to be 100% sure. Edited by Dbeto54
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 304 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
