6.2 exceeds 6l80 max torque spec?
truckguy82
Saw this post on another forum about how GM rates the 6l80e. Post was from 2010, but as far as I know it's the same tranny.
Maximum engine power: 469 bhp ( 349 kW )
Maximum engine torque: 439 lb-ft ( 595 Nm )
Maximum gearbox torque: 664 lb-ft ( 900 Nm )
So seeing as I have a '14 6.2 with 460ftlbs, and a 6 speed auto, is it exceeding the rated torque capacity stock?
Is this 6 speed any different than the 6 speed offered in the previous generation?
Here is the link to GM's current powertrain specs:
http://www.gmpowertrain.com/VehicleEngines/PowertrainProducts.aspx
2016 Hydra-Matic 6L80 Transmission ( MYC ) Type: Six speed RWD / AWD, electronically controlled automatic overdrive transmission with torque converter clutch. Clutch-to-clutch architecture, with integral Electro / Hydraulic Controls Module Engine range: 4.4L SC, 6.0L, 6.2L - gas Maximum engine power (gas): 525 bhp ( 392 kW ) Maximum engine torque (gas): 487 lb-ft ( 660 Nm) Maximum engine power (diesel): 439 lb-ft ( 595 Nm ).
Meanwhile the 8 speed is rated considerably higher:
Type: Eight speed RWD / AWD, electronically controlled automatic overdrive transmission with torque converter clutch. Clutch-to-clutch architecture, with external transmission control module Maximum engine power: 650 Hp (485 kW) Maximum engine torque: 635 lb-ft (860 Nm) Maximum gearbox torque: 738 lb-ft (1000 Nm)
Yeppers 487ft.lbs gas.
    todd wollemann
    todd wollemann
  • Who's Online   4 Members, 0 Anonymous, 575 Guests (See full list)
