2016 Silverado with Rough Country
Looks gook. Will call you if (when) I get stuck somewhere with my Alenza highway tires...
Um, I think there is an entire thread dedicated to posting pics of 2014 and up trucks. Or, did you want to have your own thread? Haha
That is beautiful. Love these trucks in white black and silver.
Sent from my Nexus 6P using Tapatalk
That was a dick comment to make to someone who hasn't posted here before.
You should be well aware of new members starting their own threads to introduce themselves and their rides.
Specs
It has a 7.5 Rough Country with 20x12 Moto Metals and 35 inch Mud Grapplers.
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
