2016 Silverado bumper filler
  • Replies 59
Wow, that looks really good so far!
Thanks.
Got the center plate cut out today from a piece of brushed stainless and started putting the holes in it.
Only thing I would of change is had the hoop come out a touch further than the bumper. That way pulling up to something if you want to touch it on purpose (or accident) that hoop does and not the flimsy painted bumper.
Nice job though. I like the first post where it is a solid shield as well, maybe even a little more. Nice to see the options.
One thing I always like is the filler plate with winch they made for the Tacoma's. Look stocked from a distance with a winch.
Tyler
I had thought about extending the hoop out past the bumper but I decided to keep it tucked in a little.
I got the hoop and upper mount welded on and made a dimple die. Tomorrow, I'll weld on some tabs to mount the skid plate and put in the dimpled holes.
64576CFB-57F9-4B98-8500-B41B415118BD_zps
DE27A7E1-A5C8-46EA-8C21-3B235B3D100E_zps
I'm a toolmaker in a tool and die shop and a self taught fabricator. My job allows me to do some designing and fabrication.
Here's some of my previous fab work.
1B5EEB3D-CC6E-4225-BA74-80080E0BE8E5-146
Almost done. Sprayed it with some charcoal gray paint for now. Probably end up having it LineX sprayed along with the side steps I plan on building.
980161D1-D4ED-48FD-BB2A-D82861B6D6B5_zps
3C9846E3-E94C-4E89-81A2-6BD2394A938E_zps
716426A2-34BB-469E-88DD-1655DD1BD577_zps
What does the cage on the diff cover do?
It's a guard to protect the cover from damage off-road. I built it strictly for looks though as I don't do any hardcore off-roading.
You're crawling up some rocks and get stuck. Put it in reverse to give it another go and hear a giant clunk. You just backed into a sharp rock and damaged your differential cover and lost all fluid. Trucks done driving for now.
Bent and notched the hoop today.
82B41FA5-4D53-4191-86D3-7B7D7DCF7690_zps
58447CCA-4D38-4B3C-9C22-F1F8AE12E588_zps
These areas around the tow hooks will be blocked off with black plastic behind the bumper.
2C424A2F-A3B5-4B63-8C6D-86DFC3D85CD3_zps
3043DF48-7A1B-430F-8235-B89516638817_zps
What gauge is this tubing? And what is the gauge of the flat metal inserts? I do have some handy workers in our sheet metal shop.
Very interesting idea, definitely like the look of it.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 473 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
