WD hitch / sway control for 5k lbs?
SteveCZ
The family and I are renting a 28' travel trailer in a week, and the spec says it's about 5000 pounds. While its tongue weight falls within the acceptable range to not use a WD hitch, I'm more concerned with sway of a 28' wind sail. The dealer said they have a spare WD hitch I can use, not sure if it has sway or not.
Biggest thing I've towed is a two place snowmobile trailer, so I'll be taking my time and being careful but also want to avoid any surprises.
Thoughts?
You can always just use light tension on the WDH bar chains if the truck doesn't squat much.
You can always stop and adjust if it doesn't feel right.
Yea I tow an 8000 lb TT with WD hitch and only use the spring bars. I've never found that I needed the anti sway plus I don't want to have to worry about forgetting it when I back up.
Sent from my Nexus 6 using Tapatalk
Sway control is nice to have but from a practical standpoint if it is windy it is safer not to drive at that time (travel in the morning) or take an alternative route that is more protected. Sway control is not going to compensate for high winds and keep the trailer from flipping over.
I usually tow a 20' enclosed car hauler - with the car, tools etc - it's only about 6,000lbs. After a couple years - when I changed out trailers - I added a WD Hitch with Sway-Control. Over-all the "feel" driving was much improved, with out the constant steering wheel inputs/corrections I had before. I towed these trailers with both 1500 and 2500HD trucks.
As stated above - "high winds" will blow you around. But high winds (35mph+) are not that common and you just slow down accordingly. Sway or Anti-sway control is more about passing or being passed by 18 wheelers at 70+ mph. Their sudden wake - that blows you momentarily sideways - causing you to over correct - and trailer going too far the opposite way - setting up an increasing dynamic in the sway - - that is what a good anti-sway system helps avoid.
If you have a lot of miles and experience towing - you most likely don't "need" it. If like me you tow two or four times a year - usually less than 1000 miles - - I see it as a good investment in both safety - and a less nerve racking drive.
If I towed a larger/heavier trailer - or put far more hours in on the road each day - I would want a 2500HD with the longer wheel base. The larger/heavier trucks are just much easier, more stable and far less nerve racking to drive towing a trailer.
FWIW,
Carl B
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
