Grade Braking
I drive exclusively in M5 around suburbia here empty and towing my work trailer.
When driving in M mode, isn't "grade braking" supposed to be off???
When I put the selector into M mode, and "push and hold" the tow/haul button for the required time....................I get the "grade braking off" in the display. Isn't it supposed to be "off" anyhow!!??? Just a wondering if there's something not quite right here. No problems with the truck; just wanna learn how this crappola works on the thing!!!
M does disable Normal Powertrain Grade Braking. Tow/Haul Grade Braking (more aggressive than Normal Powertrain GB) is also disabled when you are in M (if you have Tow/Haul on in M). Holding the button in M is disabling it in D still though. IMO, no need to disable it in D from my experience. Doesn't change a thing for driving, shifting, etc.
Why are you trying to turn it off when you're in M?
Experimenting.
Just answer my question if you can......... don't answer with another!!!
Experimenting.
Boy, that attitude will rally the troops to help you!
See if you can turn it off in M4, then you will answer your own question
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
