Linex/ Bedliner/ Rock guard inside door jambs?
Has anyone done it inside their door jambs yet, will the coating cause issues with closing the door if its linex etc.? i am wanting to do the coating part way up my doors on the outside, underneath the doors and the door jambs and the rockers aswell.
When I was in highschool we painted an entire Toyota pickup in bedliner. After about 6 months the rear quarter panel on the bed began to rust from the inside. I'm assuming that means you would prevent surface rust but it could cause the jambs to rot from the inside out.
If you painted over any rust that existed below the paint then the linex would simply speed up the rusting process. My buddy did the same thing on his Jeep Cherokee and it looked great at first but less than a year in all the unknown rust spots came up. Some parts of the line-x became soft to the touch (I'd imagine because the rust ate away at the metal below). I think if you plan to line-x the whole truck you have to do it rather quickly from new or have the entire truck stripped of paint prior in order to catch any rust spots that may be forming.
I've looked at getting my bumpers line-xed from multiple places and everyone has responded with the fact that line-x builds up enough that you may have a tough time reinstalling the bumper if you don't shave it down in some areas or if you overcoat. I'd imagine the same applies here.
I wouldn't do the rockers. All the previous gen silvys had rust issues on the rockers. They trapped moisture and rotted from the inside out. Only time will tell on these k2 body's.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
