GPS/Navigation/Bluetooth don't work
My 2016 Chevy has a red line thru gps, my compass in dash just has lines, my Bluetooth and navigaton doesn't work and my onstar doesnt either. I don't even have the red light of onstar doom. It has nothing at all. Checked the antenna and it's good....wondering if somethING could be unplugged...please help.
I had the Android Auto update applied to mine a month ago. Since then, mine has the same issue with GPS and Nav. Went to dealer today. They tried different things before calling GM. They were told to attempt installing the AA update again, suggesting some files did not copy correctly. I have to make a return trip for parts on another issue, so they plan to do the update then. Bluetooth and compass are still working. Any chance you also did the update recently?
EDIT: missed that this was in the HD forum. Mine is a 1500.
This sucks as I haven't updated mine yet but I may postpone it a little while.
  • 3 months later...
Lost my GPS on my 1500 Sierra after android auto update. Took it back to dealer and they reloaded the software for the human interface device (or something similar), and all was well again.
Can't say that i'm all that pleased with android auto, but I'll leave that for another thread.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
