Bed lights on while driving?
Paulybee
Just like the cab-mounted light, GM disables these while in motion. Maybe even any time you're not in park, I'm not 100%. You'd either need to re-wire it with a source not controlled by the BCM or find someone who can do BCM modifications (assuming that's even possible).
