2016 Axle Leak - LR
2016LTCC
My 2016 has gear oil leaking from the ABS sensor on the left rear. I cleaned it off awhile back and its slowly leaking again. Anyone else have this problem?
Gosh no need to be harsh big S_.......... I just checked mine and at 4000 miles no leaks. Have you run over any road debris or maybe a dog/deer or maybe a armadillo lately? Those armadillos are tougher than a pine knot and can really tear some stuff up..
1000's of people do. Use your warranty like everyone else.
I see a lot of OJ's posts, most of them are like the post above, useless and belittling.
Fellas some people are just that way.
I haven't ran over anything but I work with my truck and never have time to take it to the dealer, especially for something little like this. I ended up removing and smoothing off the seat for the sensor and torquing back down. I think maybe the o-ring was was pushed back. Anyways I drove it all day today and no leak but time will tell if it returns. Thanks guys I'm loving this truck! 15000 on the clock.
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 716 Guests (See full list)
