Has anyone put 3in straight pipes on their 1500 with a 5.3? If so how much and what's the sound like. I've been thinking about putting dual 3in straight or 3 in straight single with a cutout. Need help!
I havent heard a 5.3 stright piped or even a 6.2 stright piped.
Do you mean no cats, resonator, and muffler? If you mean that its going to be crazy loud and full of drone.
I have a 6.2 with the flapper and muffler delete and it sounds amazing with no drone.
No resonator either? Just pipes after the cats?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
