Want bigger tires, need to reprogram?
last truck
I would like to stay leveled but want a 32.6 inch tire, so will I have warning lights and nastygrams in my message center if I don't reprogram the truck for them. I know my speedo will read a little slower but that I can deal with, setting ABS codes I can't, so for everyone whose is running mildly larger tires did you reprogram or not and if not are you setting codes?
thanks
what size tire is on your truck now? My stock 20's are only 31.9" tall and to go to a tire that's 33" tall will only set my speedo off by 3.4% (at 50MPH on speedo, will actually be 51.7MPH) you're truck will never show you a warning message for changing the size of tire, there's just no sensors for that. Throw the tires on and you'll be fine.
Check out this link if you want to compare your current tire size to the ones you want to put on. https://tiresize.com/comparison/
Right now it has 265/65R18;s that are 31.6 inches thanks for that link.
I used hypertech speedometer calibrator, was really easy, just measure diameter of tire and program, checked it with GPS and it was right on.
Just a heads up, GM uses the same tire height in all of the calibrations no matter if the tires are 17", 18" or 20" on the K2xx trucks. As long as you run the same size tire on all 4 corners you wont have any issues with the ABS system. If you vary the tire height by 1" or more it will trip out the ABS computer and throw codes. I doubt we will see this on the trucks, but on GM cars that run staggered front to rear wheel/tire setups it can cause issues.
Case in point the 2005+ Corvette uses 18" fronts and 19" rear wheels, the tire heights are different for the front and rear of the car, but the ABS computer is programed for that. As long as you ran stock size wheels and tires you were fine, some owners went with wider rear tires and ran stock fronts and it would trip the ABS computer out due to the variance being more than 1" from stock.
I ran 33's last year. No issues at all. Never even bothered to recal speedo either. Really no reason to IMO.
You'll be fine.
Generally, that is correct, however, there were certain variations of 1500 base model trucks that came from factory with a 255/70R17 tire on them, with my 20's (275/55R20) there is actually a 2.6% difference in height. To go from a 255/70R17 to a 33 there is a 6.1% difference in which case I would then start to consider a programmer. I do admit that would be a rare case being its not as common.
You're going up an inch which is 3.2%. I recently went from a 275/55/20 to a 275/60/20 which was a 3.4% increase and I have no issues at all. I was ready to buy the calibrator and the guy told me not to waste my money unless I went up to a 35 inch tire (which I don't plan to do). Also if you're still under warranty that calibrator is considered a programmer and although it shouldn't cause warranty issues you could end up with a fight on your hands should something go wrong.
Thanks for the feedback guys, looks like I will be fine based on your experiences.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 801 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
