I just bought a 91 GMC 3500 7.4 that was a special order when new. Original owners bought it to tow a large horse trailer. It has a second battery that is isolated from the main battery but is charged by the alternator. Any idea what's it for? The guy I got it from owned it since 94 and he doesn't know either.
Usually for running electric. Maybe lights or a heater for the trailer.
Id assume running aux lights in the horse trailer But also they have lots of lights so without a second battery it can draw alot from a single battery.
It came from factory or dealer installed like this. Does camper special models come with two batteries? I'm going to go get the truck tomorrow and maybe find out more about it. The second battery is the original battery so I'm sure it's bad now.
Sent from my K88 using Tapatalk
The original window sticker shows the additional battery was an option. Kinda cool finding the original window sticker with a bunch of other papers on this truck. The original owner specked it out nice.
before the obd2 control, the more amps drawn by battery triggered a tickle to the alternator to do more.
I would have let it go.. up to you.
electric trailer brake used to be quite a monster.
frame muncher.
Today you could go from 600cca to 1000cca..and not even notice. the alternator just feeds battery with a brain now.
feeds the truck demand another way.
2 batteries worthless.
maybe diesel gurus play with them.
up until 96, the batteries claimed to be just for starting, acc key on.
that was so sick..decades of looping on batteries doing it all.Precision claim was terrible.
Today, that claim sticks. Battery is for starting.. no looping a bomb anymore.
big alternator will feed your truck. Little battery to start.
Edited by barry G
Common option for vehicles that towed a camper or trailer of some kind with need for electrical power to the trailer. I ordered it on a 1996 1500 4x4 just because I could, for no special reason. In the snow belt it was a option for snow plow equipped trucks. Dealers often installed them as accessories.
Edited by elcamino
I have a second battery and use it to run a winch. A winch can drain your battery in nothing flat. I can combine the two batteries for extra power, or reverse their role. It's also nice to switch to the auxiliary battery when you get in your truck to go to work at o-dark-thirty and find that your main battery has given up the ghost because it's old, or your son left the map light on two days ago, or.... A battery separator/combiner from Hellroaring Technologies can be invaluable if you're running off-road or frequent the middle of BFE. And, it helps to upgrade to (at least) a 150A alternator.
  • 4 years later...
    B07
    B07
  • Who's Online   1 Member, 0 Anonymous, 729 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
