Hello from TN
Seth1972
Hello,
My name is Seth Kimball and have been reading alot of the posts here since buying my 2016 GMC Sierra 1500 Rocky Ridge 2 weeks ago. Wasn't looking for a new truck but this deal was too good to pass up so I traded in my 2012 GMC Sierra. I also own a 1972 Chevy K20.
I've done a few mods to the new truck, LED foot well lights, Red LED lights in the foot holes in the rear bumper, CRE mud flaps, and tinted the front windows.
Look forward to learning new things a hopefully passing along some of my own knowledge. post-162545-0-79832500-1473561466_thumb.jpgpost-162545-0-20043200-1473561608_thumb.jpg
Hello,
Look forward to learning new things a hopefully passing along some of my own knowledge. attachicon.gif28970229344_0a56e991f2_z.jpgattachicon.gif 28970327324_07ac3dce2a_z.
welcome - looks good . any photo's of rear bumper Led's
