2014 silverado front end swap to 2016
Ricky Bloss
Anybody done a swap yet? i have all the parts painted and ready to go, I even have the forward wiring harness from the BCM to the 2016 headlights. Planning on starting swapping parts tommorow, will upload some before and after pics and follow up once done.
Anyone know how to trick the BCM to make the headlights not flicker? They will come on when starting the truck but after 30 seconds shut off, all other lights work fine.
  • 2 months later...
They come off because 14 15 silverados uses the halogen low beams as DRL low voltage for hid
What parts are needed for the swap? Parts list?
Front Bumper
Fog Lamp Right
Fog Lamp Left
Plug and play fog harness
Center Braket
Inner Bracket Right
Inner Bracket Left
Outer Backet Right
Outer Bracet Left
Guide Right
Guide Left
2 Support Bracket
Filler Panel Right
Filler Panel Left
Bumper Filler
Air Deflector
Inner Grille
Grille
Emblem
Sight Shield
Cowl Grille
Air Baffle
Front Panel
Headlight Right
Headlight Left
Hood
Front Weather Strip
Hood Insulator
Custom made Headlamp Harness
  • 2 months later...
Front Bumper
Fog Lamp Right
Fog Lamp Left
Center Braket
Inner Bracket Right
Inner Bracket Left
Outer Backet Right
Outer Bracet Left
Guide Right
Guide Left
2 Support Bracket
Filler Panel Right
Filler Panel Left
Bumper Filler
Air Deflector
Inner Grille
Grille
Emblem
Sight Shield
Cowl Grille
Air Baffle
Front Panel
Headlight Right
Headlight Left
Hood
Front Weather Strip
Hood Insulator
Thanks for the list!
you're welcome
what were the wiring differences for headlights fog lights and parking sensors?
For fog lights and parking sensors the difference is the fog light connector, you need 2 Molex MX150 connectors.
For headlights the connectors. you can find the harness on ebay
  • 2 years later...
So I have these pieces
grill with a bracket behind it not sure what it’s is or called, Headlights, bumper with fogs and brackets on it. Looking to do this do this soon do I need swap radiator support or just the grill support? Bumper has small dings but gonna get it fixed and color matched.
parts need hood, grill support for sure anything else?
