Gm family little help
I've found a couple of threads on this. But didn't get the info I needed.. I want to put another battery in my truck. I do have a tray on the driver side.. but when I go to gm parts direct I see another bracket and a battery tie down.. can somebody please let me know what I need.. I have 2 new Matching batteries..thank you for your time and input
With the little info you provided I would say a battery hold down is needed.
Mountain bad ass. :happysad:
