LED bulbs 2014 Silverado lt
Hey guys just bought some new LED bulbs and have an issue with them. Hoping someone can help me out. Sorry if this is in the wrong area and I can't find any forums on this. I'll post a link of what I bought below but anyways I installed the low beams and they both will randomly shut off and turn back on at the same time. Anyone know what I can do about that? And yes I know a lot of you will say that I shouldn't have leds in reflectors but that's not what I'm asking for I'm gonna do it anyways. Any help appreciated so thanks!
SInce the bulbs are overloading the system you need to bypass the overload relay with some very heavy wire in order to keep them in your truck.
I thought part of the point of leds was they draw less power
You should not install LED or HID into reflector housing. :M16:
Also my vote would be that your bulbs are shit. Probably a Chinese knock off, you get what you pay for. My LED bulbs were plug and play 0 issues. Only buy a bulb using Philips LumiLED, preferably made by Philips but at least using a Philips led chip anything else is a waste. The LED driver should take care of and 'smooth' any power requirements, if not return it and get a better one.
What Apline said, put some proper housings in there, don't just throw them in a reflector housing like johnny the ricer. You do understand LED bulbs have a few points that emit light right, that can leave splotchy light disbursement making some spots harder to see and blind others by the much brighter light being thrown out is. Reflector housings are designed for lower power bulbs that have light emitting evenly around it, not a few spots with diods. Start with that, then see what others are saying to fix the bulb it self, could be a resistor or something with the bulb if they are of the cheap variety.
Tyler
No. The point is better performance. Your chinese knock offs are are pulling so many amps your protective relay is tripping and resetting. No problem. Just bypass that sucker and that problem will be solved.
I def wouldn't do that. That's a fire hazard waiting to happen.... Like Alpine said, cheap LED bulbs in a reflector housing won't have good output. Sometimes the cheaper LED lights need a CANBUS anti flicker device to work correctly.
I think 'error cancellors' aka Canbus are what you need. Go to Xenon Depot.com and read there.
Where are the lights you bought? The link is gone.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 805 Guests (See full list)
