500th post
Zane
Today GM-Trucks.com had the most hits in one day than ever before. Over 200 unique users logged on and visited this site. Now if we could only get them to all sign up! :biggrin:
The main page was viewed over 1000 times and the main forum page over 2000 times.
Thanks to everyone who has supported us, onward and UPWARD!!!!!
GREAT!!! Come on guests, sign up. The more people the more interesting it gets. This site is getting better every day.
  • 5 years later...
Just curious as to where member number 1 - 100 are today. Looks like member number 5 StingRay didn't last long.
Yes I'm bored, I didn't find out I didn't have to be into work at 4am until I was already here. :P
