Bed alignment fix
Hello, I too have a bed that's shifted a considerable amount towards the passenger side and would like to try and get it aligned myself before taking it anywhere. I'm not super mechanically inclined but am working on being better. So what bolts would I need to loosen to get at the plastic pins I see mentioned above? How many bolts need to be loosened in total and where might they be located? Thanks, my truck is a 2014 GMC Sierra 1500 crew cab standard box.
  • 3 weeks later...
I just bought new 2017 Silverado 2 days ago and noticed my bed was out of alignment 3/4". I took it back to the dealership yesterday so they could try to fix. The gm mechanic said this was the worse one that he has seen and tried to fix it. He took the alignment pin out and scooted bed over. He got it close the only bad thing is he moved the bed over so far that a bracket on the frame creased the side of my bed about 3" above the passenger fender well. Now I have a truck with less than 150 miles on it with a bed that is not aligned and a dent the size of your fist on the passanger side of the bed. I refused to drive home so they gave me a rental. Service manager is scheduled to call me tomorrow to try to work something out. My question is should I demand a new truck? They would have to bondo and paint the entire passenger side of my bed. I don't want a new ($45k) truck with bondo and partial paint job. Much less a bed that isn't aligned. Any suggestions would be appreciated
so when you say its off by 3/4", where are you measuring?
if it out you can see it in your mirrors, mine stuck out half an inch to the right. then i measured from the frame to the outside of the box on both sides. when i pulled the front plastic pin out it would not let the box move enough to get it straight so i had to use a die grinder to enlarge the holes to get it straight. lots of antiseize compound on bolts anfd fluid film to prevent corrosion
  • 1 year later...
My 2018 was off by at least an inch.GM dealership in Martinez told me it is like that for a reason. BETTER AIRFLOW was the only lie they could think of. My step son loosened the bolts and took two plastic pens out and adjusted the bed
No wonder many GM workers are laid off.
  • 3 months later...
My 2019 Chevy Silverado bed is sticking out 1/4” on the drivers side and in about 1” on the passenger side in relation to the back of the cab. I took it back to the dealership and was immediately told there is nothing they can do about it do to the alignment pins and they will not change engineering. We went out and looked at several on the lot, some were in alignment and most were not. I called GM and was told the same thing, nothing they can do about it, and basically engineering is not going to do anything either. I have been a Chevy man all my life but they have compromised quality. I have noticed other nuisance problems like rattles and poorly installed items. I’m very disappointed with GM and have a case on file to replace the truck with a new one that is correctly aligned. I seriously doubt this issue will be resolved and I the consumer loses to the large corporation once again.
  • 3 weeks later...
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
