1971 C10 Cheyanne Super
  • 3 weeks later...
  • 6 months later...
It is an original Cheyene Super as well, headliner and woodgrain trim to go with the factory A/C and tilt column.
  • 5 months later...
I miss my 72 C10, Might have been a Longhorn special, had the headliner, air conditioning(was cut off when I got it), believe the 4 barrel and posi were removed, but had the wood floor in bed. It had mismatched hubs, that's why I think it was stripped, had five lug front and 6 rear.  mine was two tone bronze/copper and white.
    any interior pics of your truck?
no interior pics handy, black deluxe with woodgrain inserts.
going to redo the seat in orange/black Houndstooth cloth
  • 4 weeks later...
  • 4 weeks later...
  • 1 year later...
On 1/11/2018 at 3:16 PM, Syclone3MT said:
What kind of suspension drop do you have on this truck? I love the stance, very sharp truck!
Stock height front, 2" rear drop
Very nice truck that's been well taken care of by previous owners also. Congrats!!
Paul Jr @ GMCPauls
  • 6 months later...
