Removed chrome grille inserts?
Anyone have any instructions on removing the four horizontal chrome grille inserts? I know there are roughly 20 screws holding them in, but some are incredibly tough to get to.
I have removed the top plastic cover and can get to a lot of the screws, but some are just very difficult to get to in the bottom corners and such.
Thank you!
When I took my grille out to install the lower filler it all came out in 1 piece. I know you can take the white parts off of the main grille but I did not see a clean way that the chrome parts came off separately.
Sent from my SM-T800 using Tapatalk
To remove the entire grill all you have to do is remove the black plastic cover (12 pop up clips I think) and four bolts on the top of the grill, then pull the grill forward. It is held on by pressure clips. Then you can work on it easily.
I did this to install the bumper hole cover. It was a little scary tugging on the grill but it did pop off pretty easily.
Thank you! Definitely way easier to remove those chrome inserts when the front end is off! Appreciate it
    JD1964
    JD1964
  • Who's Online   4 Members, 0 Anonymous, 495 Guests (See full list)
