Wanting to add volt and oil pressure gauge
I have a 2011 1500 wt. The dash only has 4 gauges. Speed, tach fuel and temp. I want to add a volt and oil pressure at least. What would be the best way to do it? Was !looking at scangauge but they don't seem to do oil pressure for some reason. Not sure how I feel about an a piller cluster either
I had looked at those before but thought that was pretty expensive. I thought about a programmer that would display too but I doubt you can tune those much but I will need to change the tire size in the computer eventually Anyways
Can't you just take a cluster out of an junkyard truck? I believe these signal ( volt & oil pressure ) to be part of the GMLan and should work.
Keep us posted on what you do Rumm09. I have a 2012 W/T that I'd like to add gauges to someday. By the way, I recently changed the heater control in my W/T and all of a sudden I have a outside temperature gauge in my Driver Info Center display. Just a FYI there!
