Touch Screen Protective Film
Has anyone made a tempered glass protector for the screen? I'd love one of those. I'm not a big fan of the way the screen feels. I do love the tempered glass though.
Unfortunately it's not possible to use a tempered glass protector with this screen if you still want it to register touch. Your cell phone uses a different technology to sense your finger than our trucks.
This is a resistive screen. It's basically a piece of plastic on top of the screen, and when you press on the plastic, it bends back and touches the screen behind it, registering your touch and where it was. It registers where the two materials touch, not actually your finger. With a glass screen protector, it would spread the point where you touch too much to be able to determine what you were trying to press. With a flexible screen protector, it still allows your finger to bend the plastic enough for it to know where you were trying to touch.
I got mine from amazon the week I bought my truck. I use to do electrical work on private aircrafts. They usually had a touch screen in the galley that you could go into and access different maintinence screens as well as control TVS, DVD players, lighting, window shades and a bunch of other stuff. . Most of the touch screens had permanent wear on areas of the screen that were used a lot. For that reason I try to protect all of my touch screen.
  • 3 months later...
So, upon further research and testing, I think I'm completely wrong here. The screen has a layer on top that is usually only on resistive screens. (read: I've never seen this on any capacitive screens, ever... and I work in IT with all kinds of devices) the type of anti reflective coating resembles the plastic used on resistive screens.
Recently I saw a spec on Chevys website that said the screen was capacitive on the 2017s... low and behold, I tested the screen and found that it reacts in a way capacitive screens do. Basically, if you use a plastic stick to touch the screen, a resistive screen will react. This one doesn't.
Sorry about the misinformation. With this in mind, if someone was trying to use a tempered glass screen protector, it should work. The screen should be very similar to most modern smartphones in the way the digitizer works.
Thanks for providing an update on your findings :)
I forgot about this post actually... I have the Tech Armour screen protector installed on my touch screen and love it. Fits perfect and works great. Been on for a few months now with no complaints. Appreciate the suggestions everyone
    fourhorses88
    fourhorses88
  • Who's Online   4 Members, 0 Anonymous, 875 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
