Good cheap steel wheels?
Knightfall
At some point I want to give my truck the real old school off road look, I don't want to lift it but I do at some point want to do some real aggressive mud grips and some old school 16"-17" steel wheels. One day maybe a brush guard/winch and one of those 80's looking light bars. But that's a ways off lol. I'm not too familiar with aftermarket wheels; what are some good cheap brands to look at?
It might be even easier to call around to local dealerships and see if they have any 17" wheels that are takeoffs when someone decided to upgrade. Chances are they may still even have the TPMS in them. A lot of local dealerships will give them away for pretty good prices.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
