Superchips FlashCAL....thoughts?
Driver72
Hello guys.
So next month my wheels and tires for my 2017 Sierra 6.2 comes in (I noticed on the site it says 2016 GM trucks, I imagine it would work with the 2017 too, as they are the same, and many sites haven't fixed their sites yet to reflect 2017 vehicles. I would call Superchips to verify however.)
The tires are just 1" taller (275/60/20 the size that should come on these trucks when you order the Z71 or All Terrain truck).
Have any of you used the FlashCAL version of the Superchips. Note this is not the "tuner" version that changes your A/F ratios, timing, etc in order to get more power than the stock tune, this is the calibration tool.
http://superchips.com/products/gm-flashcal-for-truck-2545-2545/
Let me know what your experiences is with it, thanks.
Can GM tell what's been altered?
Because they still have to determine that a modification caused a failure before refusing warranty service.
Tuning puts stress on the engine that it wasn't designed to have, more power via timing, a/f ratios, etc. More power puts more stress on all the other components of the drive train, so they have an argument there.
Using a non tuner device to fix your speedo for new tires isn't changing the engine's parameters, so it's totally different in that regard.
Yes, GM can tell what has been changed and how many times. Check with your local dealer and see if they can calibrate for the change in tire size. Probably cheaper and that way the dealer did the changes using GM approved software and hardware.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
