Help with reinstalling leveling kit
Northernmoris
I have my 2017 Silverado 1500 and am installing a 2.5" upper strut spacer by motofab. I bolted on the spacer and am in the middle of reassembling it. Once the spacer is on the strut assembly must be turned 180° to line up. The problem I have is that once I do the the angle to bolt my lower strut assembly to lower control arm is too steep. Can I just do the passenger side and then swap the strut assemblies so that they line up?
I put these on all the time. I always just compress the spring and spin the strut once I have it off the car. It should line right up.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
