2015 Silverado 5.3 Engine.  60K miles.  Started chirping noise.  First little then louder.  Becoming more of a tick.  Removed all belts.  Still have the noise.  Sounds like coming from under valve cover toward front on passenger side.   So 2 and 4 cylinders.  Probably 4.  I took valve cover off.  All looks right.  I took rockers off and push rods out.  All looks good.  I sprayed carb cleaner in push rod ports.  I put back together and treated with MotorMedic products.  Then changed oil.  Still have the noise.  The noise is there until the engine heats up after about 7 minutes of running.  Then there is no more noise.  You can drive it from then on with no noise.  So....the question is WHY?  Why is the noise there until engine becomes hot OR oil pressure is increasing?  Is it that the heat expands metal and once it expands the lifter operates normal?  OR is it that oil pressure builds and it works normal after it gets to proper oil pressure?  I can't afford thousands of dollars.  Im thinking try to replace the VLOM.  Even a used one to see if I can see a change.  The next step would be replace the lifters.  Ultimately I would remove AFM which allows you to get rid of the AFM lifters.   Also there is an oil screen on the VLOM that I have not checked.
Oil pressure is higher upon a cold start and lowers as engine warms up. Oil flow, gallons per minute changes also.
I think you're going to have to replace the lifters.
You'd need to swap the camshaft as well and do a full AFM delete. You cannot just swap lifters for non AFM lifters.
I've got a 2013 GMC and have a ticker in it, but so far no misfires. If I have the kind of problems you all are having, I'll probably try to find a Hemi and make it fit. You know as in Blasphemi, on Roadkill. These AFM engines appear to be nothing but continous headaches. I didn't realize they were in the GMC's until after my purchase. I got it used. I think someone before has already programmed the AFM out, as it stays in V8 all the time. Never seen it in V4. GM boondoggle in my book.
  • 2 months later...
Hi I have a 2008 Chevy Avalanche 5.3L gas. Only 120,000 miles on it.
Flickering lights, check engine light, traction control off, service stabilitrak,Misfire cylinder #4, I replaced all plugs,wires,and swapped a couple of coil packs around, pulled injectors 2 and 4 out hook the injector up to a 9-volt battery, so I can open and close the injector while spraying the carburetor cleaner through a tube I made, I put injector 2 in the spot 4 injector, and I put injector 4 in the spot where injector 2 was ,new alternator,map sensor,  and throttle position sensor, also did a compression test that was good, still misfire cylinder 4. So I decided to remove the valve cover, all rockers are solid, no movement at all, so I did a crank test first,and all the lifter's moved, next I started the engine,and all lifters moved, within 5 seconds, lifter #4 exhaust side stopped moving. I have no ticking sound from the engine at all, could this be the VLOM solenoid? Or possibly the ECU, the ECU is what commands the solenoids to open and close from V4 to V8. I had a friend come over with his professional scanner, and the scanner showed misfire cylinder #4, brake control modular, and something with the  ECU.
Edited by Patty Leonard
I didn't know either, I just found out 3 weeks ago about the AFM issues,after researching my cylinder 4 misfire, if I knew about it,I would of had it deleted from the ECU
  • 2 months later...
I have a 2012 Chevy Silverado 1500 LT 4x4 with 5.3. I’m having problems with rough idle and traction control and stabiltrak. It’s throwing the code for the number 1 cylinder. Replaced the plug and wire and coil pack and injector. No change. Pulled valve cover off and both lifters in cylinder 1 aren’t moving. Just did a lifter change and put all back together except the valve cover. Started it up and lifters work for about ten seconds then they quit again. Still cylinder 1. Camshaft and everything inside motor looked to be in great shape when had it tore down. Should have replaced the vlom while I had the intake off but didn’t. Will installing the range afm disabler bypass the solenoids on the vlom and possibly keep from shutting off cylinder 1 lifters?
  • 4 weeks later...
On 10/20/2019 at 10:39 PM, swathdiver said:
Yes, you need to replace the VLOM and Lifter Guides too.  This is SOP with AFM repair.  It is the failure of a VLOM solenoid that causes the lifters to collapse because of a missed timing event.  If yours was built before April 2011 or so, get the new valve cover for the driver's side too.  (Well, make sure someone didn't replace it already).
Swathdiver, can you contact me.  Im in Vero.  [email protected].  Lifter issue.  Tks.
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
