07 Silverado Z71 cold knock
Found this in several spots, but still no definitive answer. 135k on my trusty single owner Z71 but over the last couple of weeks it has started a knock. Only does it when engine is "multiple hours" cold, usually has to be full overnight. Upon starting there will be a loud knock maybe 2-3 times at most that just goes away for rest of ride. I cranked with hood up today and listened from under the hood. Almost sounded like a hammer blow inside the engine (not a light ping in other words), but same as always it stopped after 2.
Ran some errands and parked at home. About 6 hours later I cranked again and no knock. I am close to trading in this truck, and the issue is scaring me that I better do it fast. 2 quick questions:
1 - Possible that it's something easy to fix since it only hits twice and then doesn't do it again until really cold? Tips to check?
2 - Fully plan to disclose issue to dealer,especially since I won't be able to duplicate on the fly. Would be easy to hide! Should I expect a huge hit on vehicle value? Even though 10 years old, I have all service records and it's in exceptional condition.
Left at Chevy overnight last week when there for regular oil change. Had to do that so they could replicate, which they did. Now they tell me they want $1,200 to tear down engine for further diagnosis, and who knows how much more to fix whatever they may find. OBD device not throwing any codes to help.
Sorry for a long first post. I am an enthusiast but not even close to a mechanic. Thoughts or advice from new bow tie friends? Thanks in advance.
~Vol
Piston slap? My 99 k1500 has better than 200k on the original 5.7 and does that when I first start it cold in the morning. It lasts a little longer than just a couple knocks tho. I understand yours is a 5.3, but I was under the assumption that the 5.3 did the same thing after a few miles.
So it's nothing that's damaging the engine? If GM has acknowledged issue and not recommending a fix, maybe the truck has some life left and won't take a hit on resale value? Runs perfect other than the startup hammer hits.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
