I have a 2015 1500 WT. It didn't come with keyless entry remotes, can I just buy a set off of Ebay and program myself?
Can you add a remote? IF you have power locks, YES you can add a remote. Why? Because you have tire pressure monitors on your truck.. They transmit their data to the Remote Control Door Lock Receiver (RCDLR). Because that module is present, you can add a factory keyless entry remote. NOW...can you program them yourself? NO. HAS to be done by a dealer with GDS2. Can you add factory remote start? No.
Thanks 15HDriver, I am guessing the remote would probably have to be bought through the dealer? Or could I purchase one online and just have them program it? I'll call the dealership and see what they say.
AU3 ( Electric door lock ) means your truck didn't come with remote keyless entry from factory. Contrary to what's been said previously here you can still get OEM remote start but the kit is very expensive because it includes a hood switch with harness, key FOBs (2), a different RCDLR an AP3 sticker to apply over your AU3 and an activation code, all this has to be done at the dealer or a certified GM shop. They will sync the new RCDLR to your BCM and with the activation will be able to download the proper menus to your BCM to enable these options.
Some different RPO codes for these new trucks. AP3 and AP8 is a 2007-2013 deal. On K2 trucks, if you have AQQ, you can add remote start. AU3 power locks are standard on all K2 trucks. Just to clarify, when I say K2, its 2014+up. You don't need a new RCDLR on K2 trucks. The OP has a 2015. If its got power locks, you can go right into the BCM and add key fobs. I have personally done this on a 2015 1500 WT. The customer was curious if it could be added, but he ended up not doing it because he didn't feel like spending the $$$ for two key fobs and $30 for programming. I took a brand new one off the shelf, went in via GM's GDS2 diagnostics and was able to add them to the truck no problem.
I stand corrected then. Thank You! Now we all know. Did you need a GM activation code like before or the menus are all there?
On the K2 trucks, with GM GDS2 you go into the BCM and simply add fobs. If its a truck that has factory keyless but no remote start, its a hood latch, two fobs and an auth. code that has to be phoned in to GM to change the programming for the truck. Those come in the GM accessory remote start kit. GMT-900 were similar (AP8 to AP3 factory remote start upgrade but those were just key fobs, no hood latch).
So in my 2018 Custom with AU3 code, all I would need is keyfobs and a reprogram from the dealer? I asked the dealership to add keyless entry and they charged me $275 and install a crap aftermarket one.
Newdude - do you know if this is the same on the Express Vans?  I have a 2014 with no key fobs, but with On-Star, Cargo, Duramax if it makes a difference.  AU3 RPO code.  Dealer tried 3 times to order key fobs, 3 button, 4 button (cargo door separate) & 5 button (remote start) and could not get any to pair with the RCDLR /TPMS receiver.  I ran this information and VIN past Dorman when I tried one of their programming modules & fob and they ran the VIN said I am missing the key fob receiver.  But I have TPMS and the receiver is the same part number.   SO..... Do I need a different RCDLR receiver (part number 20863945) and have the BCM reprogrammed to use this new key fob / TPMS receiver?  My dealer doesn't seem to understand this stuff.  They also said just buy an aftermarket remote / alarm.
What is the GVWR of your van?
Aaagh, I forgot to include that.  It's a Express 2500 Extended, Cargo, with the 6.6L Duramax turbo, GVWR of 8,600 lbs. A bit of a rare bird.
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
    • Did this ever get solved?   I'm chasing 2021 Yukon Denali electrical issues - vehicle will not enter sleep mode - we can disconnect and reconnect the battery and it will sleep - but that's likely because we powered down whatever module doesn't correctly sleep.  once we start/accessory the vehicle and turn off, it will stay at 11.5 amp draw with something keeping the SDGM alive - it appears to be activity on the X2 segment, specifically CAN FD Bus 5 - but we don't know which device and we think we've already isolated all of the devices on that segment - so what keeps the BCM and/or the SDGM alive is unknown.   I don't yet have a packet trace from CAN 5 (and since this Global B we might not get much info from it) - but the vehicle has been down for 8 weeks and previously GMC Dealer was unable to resolve "kills battery" issues with this particular vehicle - so I'm at a loss - it seems to be beyond local repair capabilities - and the number of "telematics keeps vehicle from sleeping" posts indicates this whole architecture has major issues - I hate to say it, but we might have to install a battery cutoff switch on the front grill - one of those red boat switches - to turn off the vehicle.;)  Any pointers appreciated;)  I just bought a CAN FD interface and I'm planning to try Savvycan and Peak Can SW to triage this further.
