Heater core failure and radiator failure
rlembeck
Hey guys, I have 2015 GMC Sierra crew cab, 26k miles. I started having a anti freeze odor inside the cab started faint, and grew stronger. Took it to the dealer twice they refused to smell it or fix it. They said they pressure tested the system and everything is oka. I called gmc and took it to another dealership, smell was getting worst not to mention the other dealership had my truck for over a week two separate times to try an find the problem. I took it to the new dealer an within two hours of waiting they found a leaking radiator. Which the mechanic said listen you have a bad raidiotor but that smell is strong inside the cab and the windows have antifreeze residue all over them, so I gaurentee your heater core is bad also, they fixed the radiator which I guess they said there was a bulltin out for. They fixed it and I picked up my truck drove it for 100 miles smell was still there went back and now they're replacing the heater core.. today I go and pick the truck up, apparently it's a big job considering they had to remove my front seats and entire dash. Going to pick it up after 3 days at the dealer. I'll let ya know how it goes.
If I'm not mistaken, there was a thread here recently mentioning a TSB for the cooling system. I believe they've narrowed it to a bad thermostat design creating too much pressure in the cooling system which leads to leaky radiators. I'd make sure the dealer is aware of and acts on the TSB before it happens again down the road.
What is the TSB? Link?
Here's the link that I remembered seeing:
http://www.gm-trucks.com/forums/topic/194376-letter-cycling-thermostat/?hl=letter
How does a thermostat "create" pressure?
If I were to venture a guess based on the link above, the thermostat is likely staying closed longer than it should. If the thermostat bypass isn't designed properly, and the thermostat is remaining closed more often or longer than it should, then the system could see pressures higher than normal for longer periods of time, putting additional stress on heater cores and plastic radiators. Resistance to flow increases pressure does it not?
No it's not caused by pressure. The thermostat was originally designed to open at 207 degrees but it cycled open and closed too often, causing the radiator to distort and crack.
Mine was recently replaced at 22k miles.
  • 4 weeks later...
Well they replaced the radiator, and Heater core,.. still have a antifreeze odor coming in the cab and have my windows fog up with residue.. it's been at the dealer a few days hopefully they can figure out the problem. Also need new dash plastic and speaker since they were warped an bent from being taken out and reinstalled, gotta love your new 50k all terrain truck being taken apart
I sure like the old Ford truck design where the heater core and A/C evaporator are in a box in the engine compartment and easy to replace without ever getting inside the vehicle. I am not sure if they retained that design on newer trucks though.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
