2016 2500HD Denali roof leak
Reager75
Mine started today. Looks exactly like yours.
Ugh. Don't be surprised if the bottom of the knee bolster on the driver's side dash is wet and there is a line of water right under the dash on the floorboard.If your TPMS and keyless entry stop working, those both go to the RCDLR that is in the dash and can get wet from this leak.
  • Replies 41
Picked up new truck Wednesday. Usually garage it but since it has been raining for the past two days it is outside Hope it passes the water test
My. 2015 had the leak so odds are ?????
Guess if it stops raining I will have to change photo
That's where I first noticed it, a pool on the floor mat under the parking brake pedal.
Stopped at the dealership today. They were all to aware of the issue. Asked if I wanted them to do it right then. He said they had done so many they can have it done in 30 minutes. Unfortunately didn't have the part, but overnighting it so they will do it tomorrow.
I asked him what is different with the new part. He said the seal on these was small and wore quickly. Said the seal on the new antenna is larger. I would suggest if you have a 2016 you get it changed. Sounds like it is more likely a when than if it occurs. So far he said 2017's have not had this problem with the new part.
Mine started today. 2017 Sierra Denali 1500. Guy at dealer acted like he had never heard of such a thing. LOL. Sitting at the dealer now. We will see what they say.
Does the water on the floor come from the same leak from the antenna fin? For the record, I've got the leak too. Bought new in August 2016, currently has 14k miles.
Yeah, same leak.
Am I better off fixing it myself with Silicone or taking this into dealer? Just noticed the leak started with the recent rainy weather.
Yes. I first noticed a small puddle under the parking brake. It was dripping from under the dash onto the parking brake pedal and the floor. Later it was wet on the left windshield post and at the pivot point for the drivers visor.
Dealer was very aware of the issue and said they have done a lot of them. If your dealer is telling you otherwise its either a lie or they don't sell many trucks. Quick easy fix. Apparently a redesigned seal from what the collision shop said.
Duplicate post
Its under warranty, get it fixed!
They all have that gap in the gasket at the back. I don't know why but they do.
There is a reason for that gap. The antenna base has a double seal. The outer seal is just dust seal and the gap is there to allow moisture to escape. The actual water seal is under the center of the base, smaller than the outer seal and it is that inner seal that actually keeps the water out. I suspect that they are not tightening the bolt on the underside of the antenna base to compress the water gasket sufficiently, or the bolt comes loose. Or the seal is somehow misaligned. Then the seal is no longer watertight and water intrudes inside the truck through the bolt hole.
Maybe they could have come up with a better design. but given what it is, it will not leak if assembled and installed properly. I have a similar antenna base on my 2009 Impala LTZ and it never leaked a drop in 115k miles/8 years.
As I posted before, I was told that the replacement antennas, same as on the 2017 model, is a new design of the seal. The dealership said they have replaced numerous ones, the seal was too thin. The new ones have thicker seals.
I didn't see the new parts to compare but that's what I was told.
There is a reason for that gap. The antenna base has a double seal. The outer seal is just dust seal and the gap is there to allow moisture to escape...
...but given what it is, it will not leak if assembled and installed properly...
But the problem is the gap is on the uphill side of the antenna. There is no gap on the downhill side so moisture can't escape. Water on the uphill side heads downhill right into that gap and doesn't have anywhere to go once in there. And the sharkfin starts filling up with water. Once there is enough water in there, it gets past the inner seal. When I discovered the leak and thought it might be the sharkfin, I wiggled the sharkfin and a ton of water came flowing out of it. It was full of water. So, the gap IS a problem on these trucks because it lets water in but won't let water out.
And, the "assembled and installed properly" is a huge red flag. Proper design and assembly procedures that don't require an assembler to properly put it together will prevent this. Take the assembler out of the process and the problem goes away. Any time a person has to make a subjective decision (tight enough, too tight, correct orientation, etc?) there will be problems. Make it so the assembler just has to put it on and not have to make any decisions about how it gets installed. Proper design will make it so that can happen. Proper process development will ensure the assembler can't make a mistake. The old phrase "technician proofing" applies here. It amazes me that this problem has been around since at least 2014 and it hadn't been addressed at the assembly line. Yes, it seems like maybe the 2017 models have addressed it, but now there are a bunch of unhappy 2016 owners who should have the benefit of lessons learned from the previous years. I worked many years as a process engineer and this is a prime example of poor design and assembly process. Time will tell regarding the 2017s.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
