6.0 swap exhaust questions.
Tuner should have done the relearn then
  • Replies 41
If it is a Gen 4 (cam sensor on the front cover), you have to deal with the difference between a 58x reluctor and the original 24x reluctor. The cam reluctor is different also. Lengenfelter has a conversion module that is designed to convert the signal so the older PCM can handle it, even with the tune.
The engine was out of a 04-05.
Sent from my SM-N900T using Tapatalk
It's highly unlikely the lack of charging is causing the misfire. My '05 regulates the charging system to maximize fuel economy. I'm not sure if that's the same for the older ones. Does the light come on? Also, check to make sure all your grounds are back on and tight.
If you have access to a scanner with OE live data, you can see misfire history that can help you narrow down the problem. Launch makes an awesome little scanner for about $325, the CRP123P. It has OE level data on engine, transmission, Abs and airbag for all makes and models and free updates for life.
All I have is my Bluetooth scanner. The alternator was definitely bad. Didn't fix the misfire, but now the check engine light doesn't come on as fast or as frequently as it did with the bad alternator.
OK, there is significant history on 1,8,6 and some on 5. They aren't dedicated to one bank or the other. It's good to start with the basics. When it cranks, the starter pulses should be nice and even. That's a good indication of good compression. Pull the plugs and make sure there isn't something obvious, like a closed or excessive gap, or a broken ceramic or carbon tracking. You can also see if they are wet with fuel or if there are any deposites.
The thing that is odd is 1-8 and 6-5 are companion cylinders in the firing order. It is possible that there is a crank relearn needed. If the PCM doesn't know where the crank is in it's rotation, it will think there is a misfire condition. It won't really know exactly when and how to fire the cylinder either. It may be a good idea to do a relearn. You don't have to go to a dealer if you don't have the ability. Most high end scan tools can do it. If there is a good shop you trust that has a fairly up to date scanner, they can do it for much less.
Is it very harmful to run the engine befor getting this fixed? I won't ha e much spare time for a few days.
Good question. I don't think it will do any major damage, but I don't want to say for sure.
Crank relearn seemed to fix it for the most part. I still get the code but it only comes up as a pending falt. I did turn the light on once but hasn't come back (as a current fault) sense.
Glad it's doing better. Drive it for a week or so and see how it does. It may have been trying to compensate for so long it has to re-learn what is normal. If it doesn't get better after a week or maybe 200 miles or so, go back to the basics; spark, fuel, compression. I really think you have it nailed, I wouldn't stress about it.
Looks like no one is really sure how back pressure effects engine performance.
I'm mainly worried about losing low end hp/tq. Does the lower compression on the lq4 make any difference?
Is a header wrap worth the money or should I just leave the SS bare, with no coating?
I dont know about back pressure, but the 'speed' (or velocity) at which you move the exhaust out the back increases torque. The amount(or flow/volume) you get rid of increases horsepower. This, I HEARD!
Misfire codes haven't come back yet.
I am having a issue with the new transmission. It has a 2000rpm stall. If I get close to 2k rpm it shudders pretty bad. If I drop down a gear or bring the rpm up it goes away and feels/shifts fine.
Is this normal? Hopefully I won't have to replace it. I don't think the tunner did anything for the transmission computer.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
