Catchcans?
Chance Neel
I wasnt a big believe in them. BUT, I frequent performance car/truck forums looking for various things for me cammed LS1 mustang. I've ran across a lot of threads from serious car builders saying the direct injection engines benefit greatly from catch cans.
I ended up ordering one of the cheaper ones from elite engineering catch cans (a sponsor site and no Im not affiliated with them). After only 500 miles with it installed I have a few ounces of milky oil in the can. Do what you want, Im giving a genuine review of my opinions, but I wil be putting one on all my cars from now on. If they increase the longevity of the engine is up in the air. However, they prevent a lot of stuff from entering the engine.
