AC high pressure switch
First off I'm new to this forum and I've been doing a lot of searching can't seem to come across anybody else who has the same issue I have. Anyhow I have a 2006 Silverado 2500hd 6.0 motor just got the truck. Ac compressor will not turn on. Here's what I've done
1 all fuses and relays good
2 checked pressure on system and it's at 22 lbs which I know is low
3 tried putting a wire in the high and low pressure switch to force the compressor on( nothing happens)
I have yet to try to run power straight to the compressor but here's my main issue. From my understanding there is gonna be 1 low pressure sensor. And 1 high pressure sensor. Right or wrong?
So I have 2 plugs coming out of the same wiring harness at the top and I have no idea what the one that's not plygged in goes too. It's the one with the blue back on it. Does anybody have any suggestions as to what I can do to recharge the system without the compressor running? Maybe that would tell the sensors it has good pressure and will in turn run? Thanks I'm advance
I would suggest going somewhere, perhaps a dealer, that has a scanner that can read all the computers on your truck, as there likely are codes set for your a/c computer that should indicate why the system isn't working.
Second, subscribe to alldata.com or helminc.com for the full-service manual for your truck. It will tell you how to get your system back up and running.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 566 Guests (See full list)
