Interior trim removal (specifically steering wheel/cup holder)
Hey everyone. My buddy from high school owns a hydrodip company and is going to dip my interior trim. I can get the vents and stereo trim off but can't seem to get the cup holder trim and steering wheel. I wanted to ask if anyone else has reminded these pieces yet before I risk damaging them. TIA.
I've been trying to tackle this as well... There is a thread on this already but I still haven't been successful... See the following thread.... Removing the Air Bag and Steering Wheel
https://r.tapatalk.com/shareLink?share_fid=33003&share_tid=163179&url=http%3A%2F%2Fwww%2Egm-trucks%2Ecom%2Fforums%2Findex%2Ephp%3F%2Ftopic%2F163179-Removing-the-Air-Bag-and-Steering-Wheel&share_type=t
I just want to remove the silver trim from the steering wheel not touch the airbag at all. I planned on removing the negative side of battery and fuse for it once I figure out how to remove the trim.
Same here but I have the rear steering wheel controls and I think the screws to release the trim pieces are located under the airbag for which the ones without the rear controls are located on the rear of the steering wheel... I've attempted to remove it but have been unsuccessful this far.
Oh F. Screw that then haha. Not worth the trouble. How about the cup holder one?
I've just decided to vinyl wrap all my trim pieces instead of having the trim pieces dipped. Vinyl is cheaper, there's more options, I can change it, and I can do it myself... As for the cup holder, it should just pop out... Mine just snaps in...
Ok. I'll try again tomorrow for the cup holder. I was worried about snapping it.
Heres a video of removing the center console trim. Its from a 14, but seems to work thru 17 my. You should be able to get the cup holder off once the console top is off. I would recommend NOT using a screw driver in those areas (unless you want permanent dings).
I did mine when I replaced the wood colored trim with the silver trim.
Steering wheel is a pain as you have to remove the air bag to get the trim off.
There's no difference between 2014 - 2017, they're all K2XX.
Sent from my SM-G930V using Tapatalk
If you are talking about the cupholders they are definitely different.
On the 2014/2015's the cupholder was "moveable" like the one in that video (see the slots near the front of the console?). They took this option away on the 2016/2017's and made the cupholder part of the trim around the edges.
That's what I thought. Is it possible to remove just the silver trim on the 16/17?
I didn't know, I like the ability to remove the cup holder and store stuff below them. Anyways that's a small difference, the process for removing the trim pieces should be the same. There's some screws, then you pop it up and remove the trim or unhook the connections up front and then remove the trim.
check out BC Chris' build - he has one of the best writeups on removing trim, including on the steering wheel (see post #56)
http://www.gm-trucks.com/forums/topic/189651-bc-chris-2014-silverado-slz-z71/page-4
I have a 16 and removed my cup holder a couple of times. You have to work carefully but it will disconnect. Here is a picture once the top is off.
"yup, vinyl wrap is much more practical and cheaper. My vinyl wrap project was installed by Gatorwraps and I am very satisfied"
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 799 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
