Erratic rpm at road speed
Cruising this morning at 55 mph. Rpm needle bouncing up and down about 100 to 200 rpm. Can very slightly feel it 'seat of the pants'.
Check engine light was flashing on me for about 5 seconds couple days ago but then went away by itself.
Have 110,000 miles on truck. 2014 silverado 1500 5.3 liter 4wd crew cab
Sent from my SM-G930T using Tapatalk
Flashing cel is random cylinder misfire. Had this same problem mine was bad gas tho
That's what it feels like. Same gas station for years and no issues.....
I was thinking spark plugs right away cause felt like a miss. When i use button on steering wheel to add speed the initial acceleration from 55 to 58 is kinda jerky.
Dump in bottle of HEET?
Up date. While on cruise control this morning rpm started spiking waaay high like up to 4,000 rpm. Went to turn around and go back to shop. Now can't move. It just revs up.
112,731 highway miles on this POS and the trannies gone unreal
That sucks man, keep us updated!
Hi Bryceraisanen1,
I’m sorry to hear your Silverado is experiencing this rpm concern. Please know, we’re available via private message should you wish to discuss your concern in greater detail.
Best,
Anthony
GM Customer Care
So yes trans is definitely shot. As described to me, the 4-5-6 clutch burned up. As a result of that, metal shavings scattered all throughout the transmission.
Options are: buy new trans for $4200 that will have 100k mile warranty OR have dealer repair the existing transmission for $1900 which would come with 1 year warranty. GM would cover $800 if I go with the cheaper dealer repair.
Or, they'll give me $15k for trade, as it sits. Has about every option except leather. Paid $43,000 almost exactly three years ago.
Heckuva bill for a daily cruiser with 112,000 miles on it.
That sucks, I'd take the trade in deal
Huh? Deal? That's like over $30k for an upgrade on a truck that's only 3 years old! They quoted me $44,000 for a new truck similarly equipped b4 taxes.
You probably make/have more money than me, but is ownership cost on a half ton truck supposed to be more than my house?
What i ment was if you arr still making payments might be worth the trade in the long run. Having it rebuild with metal shavings and such might be a gamble, and 4200 is not a small amount of money. But if you own it outright tgats a different story.
Bought it cash.
Bought it cash.
In that case id try to go new, if its feasible and get the 100k warranty. Did thry say what the cause was?
Thats not a lot of miles
Not specifically. I asked what burns up a clutch. They said "heat".
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
