2016 Silverado Rear cup-holder mod
Is there something I can buy for my rear passenger that would attach to the console. The door cupholders are tiny and not ideal for holding anything. :\
What do you drive? DC or CC? The cupholders in the rear seat fold down console seem to work fine for me and the doors hold a bottle water just fine also.
Ditto. Especially if you have 3 kids in the back!
You could always get one of the cupholders from an older front jump seat and mount it to the rear seat. This would give you at least 2 cupholders.
  • 2 months later...
DC
yeah the doors hold a water bottle but when you travel with a group and everyone has large ice coffees or coffees and other drinks in general the doors are inadequate. I'd hate to say it but I have to give a bonus point to Dodge on their cupholders for the floors and consoles are very nicely sized and properly placed. :\
DC
True, good point. They're perfect for water bottles and anything within that size but not for like a 32oz drink in a styrofoam cup or anything. Dodge does have some nice cup holders.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 620 Guests (See full list)
