Antilock Brake issue help
Hi folks,
I have a 2000 GMC 2500 4wd truck.. (SLE)
Every brake line on the vehicle has rusted out and I've replaced them one by one.. I've actually gotten quite skilled at what to do when I my vehicle's brakes fail in traffic.. (Practice makes perfect eh?)
The truck seems to have developed a strange problem with the brake system.
Whenever I come to a slow stop, the anti-lock brake system kicks in and makes a strong groaning sound and pushes back on the pedal. This only happens when the truck is just about to come to a complete stop.. It does not happen during the initial braking from higher speeds.. only when the vehicle is under 5 mph or so.
If I smack the brakes from highway speeds, the vehicle stops fine.
I also notice that it sometimes wants to pull to the right and it makes me think the problem is in the left front brake somewhere.
This groaning started off very intermittent about a year ago.. It would act up once occasionally when I drove the vehicle someplace. Now the problem has gotten worse and it does it whenever I stop.
I should note that when this issue occurs, the vehicle WILL NOT stop unless I pump the brake pedal once.. then it goes away and the vehicle stops as normal.
My brake pedal is NOT squishy and I seem to have good strong brakes when I'm decelerating from highway speeds.
What in blazes is going on?
Take the front wheel speed sensors out of the hubs and clean the surface on the hub, and if the wheel speed sensors didn't crumble taking them out put them back in. If they did crumble then put a new sensor(s) in. What usually happens is the hub rusts, pushing the sensor up away from the the hub and causing a poor reading from the sensor at low speeds. It will read 0 mph and activate the abs.
Wheel speed sensors most likely. If its pulling to the right then the left wheel is where the low speed abs activation is occuring. I just had this same issue on my old truck. As SILVER SLED mentioned you should try cleaning the wheel speed sensors first and if you are still having issues then replace the sensors.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
