Trailer dolly
Looking for something to move my tandem axle 21' boat trailer in and out of garage. I have close tolerances thought it might work better without truck and use dolly. Any one have first hand experience with something like this? Thanks
If you have money to spend, they make motorized trailer dollies for just this application. Length won't be your issue, weight will be for capacity of the dolly...I know guys use these for campers.
I've used non-motorized trailer dollies on smaller trailers and they work very good. But I personally wouldn't use a non-motorized one for anything over 500 pounds.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
