2" vs 2.5" rc levelling kit
What is everyones opinion on a 2" or 2.5" rough country levelling kit for my 2015 sierra all terrain double cab, i have the 20" at wheels and have 285/60duratracs to put on it. I know that the only difference is that the 2.5" kit replaces the rear blocks with an extra inch but which would make my truck sit the nicest. I like a slight bit of rake but not much but dont know what the best option is
2.5 has a 2 inch bottom and 0.5 inch top spacer in the front
I'm looking at the 2.5" kit also now. Truck has 45,000 on it, I think the springs have settled a little, ride height is still good, but I do think sits a little lower overall now. I did a 1" front end lift about 30,000 miles ago which has worked well, thinking about going up another 1" all around. I would just use the lower spacer and swap out the rear block.
Ok i guess i will just go with the 2.5 kit since it is a bigger lift, i was told the only difference is that the 2.5 adds an inch to the rear but will just go with the bigger lift anyway
My understanding is that the higher the level, the harder it is on your suspension components. With 1.5" to 2" level you don't have to raise the back, it is easier to install, suspension angles are favorable and your truck still looks cool! There are hundreds of posts on this topic in this forum. I found reading most of them very useful and saved me a lot of money and possible regrets!
I
I would agree with this completely. I think 2" front end lift is the limit before swapping in upper control arms with modified geometry. 3-3.5" kits out there, not sure what purpose they really serve. My view is if you can't fit the tire you want with a 2" lift, odds are pretty good 3" isn't going to matter much, then you're off to the 4.5" stuff with relocated differential.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
