Aux port not working
Hello guys, I have a 2014 Silverado 1500 regular cab and when I use my aux cord the speakers will make static noises when the bass hits , but when I'm using my sd card or just the radio it's perfect. For some reason it only does it with the aux cord, I've used multiple cords so I have no idea what it is. Hope to get help.
Take the cord out, stick your finger on the aux port and wiggle it, if it moves, you need a radio. Some people use really long cords and they eventually get snagged on something and it's breaks the aux jack. I've seen it a ton of times.
Need a whole new radio? Yikes! I'll check it out
You need to replace the USB/aux/sd port. Had the same static noise in my truck. Replaced the port and no more problems. Quite a few have had problems with them.
You need to replace the USB/aux/sd port. Had the same static noise in my truck. Replaced the port and no more problems. Quite a few have had problems with them.[/quote
Is it hard to replace? You have a link for purchase ?
Is it hard to replace ? Do you have a link for i can buy?
pretty simple, the old pulls out, disconnect the wire loom, plug the wire loom into the new and snap it back in the hole. the part number I used for the one in my center console was, I bought it through GMpartsdirect.com.
AUX JACK Part # 22990883 Quantity 1 Amount $56.27
Okay, I was thinking this is he old style with the aux port made into the front of the radio. Sorry....yea you can replace that port
