Ichie123's 2015 GMC SIERRA SLT 5.3 Build
Ichie123
  • Replies 30
How do you take out the radio and vent trims, is there a how to on that or a video?
I plan on wrapping mine vs dipping
The radio trim is just held in by clips. If you have a plastic trim removal tool you can wedge it in between where the plastic and the leather touch.
For the side pieces for the vents, its best if you take the side panels off where the fuses would be on driver side. That whole piece is held in with clips. Just pull. The vents are held in by 2 Philip head screws.
  • 4 weeks later...
Finally decided to relocate my antenna to under the hood. I don't use fm or am stations and personally just think it looks bad.
Ps. My trucks dirty.
After 61k miles I decided to finally replace my cabin air filter out with the K&N cabin Air Filter.
  • 11 months later...
Used philips led for the license plate lights and they are BRIGHT!
Enjoyed having the ProClip for my phone so i got one for the opposite side for my iPad.
Added an Amazon Firestick to the radio with an hdmi switcher so that it’ll retain the use of CDs and DVDs
    Bert 22
    Bert 22
  • Who's Online   5 Members, 0 Anonymous, 716 Guests (See full list)
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
