Started the truck today to go to work and engine light came on. Says " rough idle cold start" it was middle of the afternoon and 72 degrees ? It's a 2016 silverado with 37000 miles... any ideas about the rough idle ?
I've seen this DTC a few times. Most of the time it leads no where really. The ECM noticed a low fuel rail pressure on start up. This could be a high pressure pump leak down or a piece of debris around the rail sensor. I'd clear the DTC and drive the vehicle and see if it returns. I wouldn't be to worried about it, especially if it idles okay.
I've repaired a few trucks with this dtc. They have always been a bad injector, leaking down.
Rough idle/cold start code on my 2014 Chev Silverado for the second time now. First issue was at 84,000km. All 8 injectors were replaced under warranty June 2016. Now just over 1 year later and at 123,000km the light is on again so I brought it in and same thing. They said it was all 8 and it's not covered under warranty but maybe GM would do something being as my warranty just ran out at 120,000km and one month after the year warranty on the first 8 injectors being replaced was up. No response from GM and now they are saying only two injectors need replacing. My truck has been at the shop for a week and I'm on the hook for the rental. They say they will cover half the cost on a goodwill plan. My cost is $580.00 plus a week of rental costs. So how long until the next 6 go? What is causing this issue is what I want to know. I only run premium fuel....
Edited by Chevyguy2014
  • 2 years later...
My 2014 Silverado with 72k miles had the same issue took it to dealership and had to replace injector cost me $2k. Not happy sent a complaint to GM, as I was getting it fixed they said we can just sell you a new one I was like no I'm almost done paying it off.
How many of you people that had injector failure were actually a failed injector or just failed injector compression seals. I had one fail and when I replaced it the compression seals were gone. A week later 2 of the new injectors had bad seals again. I'm not sure if this is an injector seal issue or an issue with the engine itself.
When my seals failed you could hear a puffing coming from under the intake from the compression gases blowing passed the injectors. 036c0817e89af790f210ec9e45bd680e.jpg72e2be807ea65762883f6de747e2b875.jpg
When my seals failed you could hear a puffing coming from under the intake from the compression gases blowing passed the injectors. 72e2be807ea65762883f6de747e2b875.jpg
I wonder if this is the reason so many injectors get replaced. Are the injector seals serviceable or is it just replace the injector and hope the seals hold up?
They're serviceable with a special tool and each injector comes with the seals for the other 3 on that bank since they're not reusable. They're a Teflon seal that has to be stretched on and resized. The tool costs around $180.
I have the same issue. Cold start rough idle. The truck is running rough. We had all 8 injectors replaced,the ECM reprogrammed. After reading much about this, I asked the mechanic if by chance there is some sort of air or fuel line leak. He told me he checked injector preassures with diagnostic machine. and his machine would tell him if that was the case. He is suggesting I replace the ECM next.
Perry
    250.3k
    Tiffanyrose
    Tiffanyrose
  • Who's Online   4 Members, 1 Anonymous, 1,112 Guests (See full list)
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
