has any done or thought about putting 2016 head lights and grill on a 2014
i thought about buying a new truck but i like my truck and i couldn't find the one i liked
i've already done some checking . the radiator support and the fenders are the same
i know the wiring would be different. i do like the looks of the 16's
If you have a GMC Sierra not a big deal to swap headlights for 16+ ones. The Silverado ones require a new hood, fenders, bumper and such. Way more involved for sure.
the fenders are the same already checked that. i do know the hood has a different part #
Hood, grille, bumper, lights and misc other stuff. There's a few threads about it. Not worth the money, unless the front is smashed and is getting replaced.
