Oil change help
Just bought a 2011 Silverado a few months ago. I changed the oil last week and now the dash messages is telling me I need to change my oil.
Was I supposed to do some kind of reset because it's counting mileage, or is the truck actually checking my Oil? I've never had a truck with this feature so I'm not sure. I checked the dipstick and it shows full.
Thanks in advance.
Yes. It is in the manual how to do it.
That darn manual it'll getcha every time
RyanbabZ71 that is incredible you have 23,175 posts if that counter is correct? If you spent like 5 or 6 minutes on each one you have invested almost 2000 hours here (A years work LOL) My Hero
The computer calculates when it should be changed - but has no sensor to tell if it must be changed.
Sent from my XT1053 using Tapatalk
Thanks for letting me add to my post count. Those 23k posts started back in 1999 when the site was started prior to the launch of the gmt800s. I am also a moderator so that also increases my post count.
GM OIL LIFE SYSTEM...HOW DOES IT REALLY WORK
This is taken from the May 2003 GM Techlink publication
How often should engine oil be changed? 3,000 miles, 5,000 miles, 7,500 miles, 10,000 miles? Actually, all of these are correct, depending on operating conditions. Oil life is affected by many factors other than just miles driven. The type of driving, temperature, and engine load all play a part.
That’s why GM has developed the GM Oil Life System, an electronic watchdog that keeps track of all these variables and notifies the driver when it’s time to change oil. This system has become standard equipment on nearly all GM products since 2000.
Briefly, the Oil Life System is programmed with a certain number of engine revolutions. As the engine runs, this number is reduced until it reaches zero, and the Oil Life light or message comes on. But there’s more. Operating the engine under low or high temperatures, and under high load conditions subtracts (penalizes) extra revolutions, so the light comes on sooner. Changing engine oil according to actual need rather than an inflexible schedule provides several benefits.
First is simplified determination about when to change oil. No more decisions about normal conditions vs. severe conditions. Second is reduced operating costs for GM’s customers, who now have to change oil only when it’s needed. Third is minimizing the amount of used oil that must be disposed of. And fourth, engines will always be running with sufficiently fresh oil, for long life.
Traditionally, the vehicle maintenance schedule has been based on miles or time, while the oil change interval is now based on the GM Oil Life System.
When the change engine oil light or message comes on, it means that service is required on the vehicle. I should be serviced as soon as possible within the next 600 miles. It is possible that, under the best conditions, the engine oil life system may not indicate that vehicle service is necessary for over a year. However, engine oil and filter must be changed at least once per year, and at this time the system must be reset.
    ar0517
    ar0517
  • Who's Online   3 Members, 0 Anonymous, 761 Guests (See full list)
