2006 gmc 4x4 problems
I have a 2006 gmc 1500 4x4 bought truck was told transfer case was bad the guy I bought truck from was driving it with no encoder motor on it said it went bad but he was still driving it so it quit pulling on him wouldn't go front wards or back wards just rev up and when u shifted from reverse to park it would make clicking noise. So I towed it home put new encoder motor on it hooked everything up started truck nothing no lights on switch and service 4wd message on dash tried a new switch still nothing checked all fuses with test light please help.
  • 6 months later...
Check the fluid in the xfer case, if it's red change it to AC Delco Xfer case fluid. It's Blue and expensive. I have found it at the local GM dealers only. My Xfer case shifted slowly if it shifted at all and I had messages on my dash until I swapped the fluids out, now it works and no messages. Good Luck.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
