Desktop, Laptop, or what?
Noctua nice, seems I'm not the only one left using expensive air coolers instead of AIOs. Does it not clear the ram oriented the other way?
Sent from my Find7 using Tapatalk
  • Replies 55
It actually clears both ways. I just wanted to have to eject out of the top of the case, since I thought it would be less restrictive than trying to push it out of the 120mm rear fan.
This cooler is awesome, it sits at 40C in gameplay.
Sent from my SM-G920V using Tapatalk
Here is the finished (for now) replacement:
MSI X370 Gaming Pro Carbon motherboard
AMD Ryzen 7 1700X cooled by Noctua NH-D15
2X 8GB Corsair Vengeance LPX 3200 RAM
ASUS GTX 1060 6GB
Samsung 850 Evo 250GB & Seagate Barracuda 2TB
Fractal Design Meshify C, 2X Noctua NF-P14s redux front fans
Need to upgrade that video processor to a 1080 or 1080 TI.
Can you not install a M.2 hard drive on that motherboard instead of the Evo SSD?
Never went to water cooler, they never hold up over time. I’ve got 4 fans running, 3 feeding the inside and one exhaust.
Looks nice! Too bad you went with AMD over Intel!!
Prices on 1080s are crazy now, I'm going to wait on that a while. The 1060 can handle Ultra settings on every game I've played so far.
I already had the 950, I'm hoping to upgrade to m.2 once memory prices are down. This board has 2 m.2 slots.
I went AMD largely because of the Coffee Lake debacle. Meanwhile, AMD unlocks all their chips and is transparent about chipset compatibility timeframe (AM4 supported til 2020). AMD was a no brainer.
I have about 50% cpu usage in AC Origins so I can't complain.
Agreed, I got a killer deal on my Nvidia GEForce 1080 (way overpriced currently) - BUT I had a $250 gift card to Best Buy I won at a suppliers door party, so I figured I might as well.
The m.2 is phenomenal.  I've got the samsung 512 GB m.2 - I can hardly sit down before the computer is already booted up.
But what do you need 3.4 GHZ of processing power for if you don't have a 1080 graphics card??  The 8 cores on that is nice.
I actually have the Intel i5 8400 Coffee Lake series, able to run 2 games with 3 screens running smoothly.  I've been following along with the microcode info, just waiting on a Bios update I believe.  Got mine in December before all of this came out.  Very interested in the i5 8600k now though.  It should drop in price once the i5 8600 comes out.
I mainly got the R7 to futureproof, I shouldn't have to mess with it for a couple years and the price was right.
I am not sure when the next stage of gpus are coming out, but at that point I'll either update or grab a 1080 at a discount. I wish I'd bought one when they were cheaper.
Yeah that's what I have is a NH-D15. $88 and going strong since mid 2016. Only have 2 problems with it. My ram is too tall so I have to run it like you did in push/pull instead of push/push. For some reason mine whines in this setup once middle fan ramps up. I'll have to contact Noctua to get the AM4 mounting bracket when I build a new system.
I don't think pull is a bad way to set them up, should be easier to clean off dust.
The cooler I got is the SE-AM4 model, which comes with vertical and horizontal AM4 brackets, so that's an option if you want to keep the cooler on the old machine.
I do get some whine, but it's not noticeable if I have any audio running. My intake fans are louder.
It's not a bad option, but I'd rather run push/push to get rid of the whine. My rear exhaust fan could almost be the pull anyway. All I have to do is contact Noctua after I buy and receive the AM4 board/cpu to show them I bought it and they'll send me a bracket free. Or I can just buy a bracket from them before I upgrade. With the way component prices are continuing to suck I think my boat will be getting thousands of dollars of electronics before I spend a couple grand on a new computer build.
  • 1 year later...
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
