Upgrade Preference - Catback or Tuner 2017 Silverado 5.3
Thanks guys. I went to the diablo forums and sounds like there are still some issues for some people. May not have all the bugs worked out yet? Anyone with a 17 5.3 6 speed have input?
I went with hp tuners. I bought the handheld and the software. I also had to send my TCM (trans controller) to them to get it unlocked as the new T87A TCM's are locked up like fort knox.
I am going to have a local shop do the tune but I want to learn the software myself and also be able to flash back to stock on my own.
HPtuners also offers this which I thought was really neat.
Sent from my SM-G930T using Tapatalk[/quote
That seems like a tremendous amount of work. you have to send them your info every time? And wait for them to send you a tune?
If you prefer canned tuned instead of a tune specifically for you truck and mods thay came from data gathered from your truck than you may be better off with some thing simpler.
Yeah not looking to get crazy with the tunes just a little performance and AFM delete will do. The diablo sounds like it maybe the trick as long as it works and can change from time to stock pretty easy
Diablo doesn't work. Had a friend who manages an O'Reilly store call them yesterday because they supposedly have a new update that allows their tuner to work. Tried 3 times and it would not load after updating the tuner. Wild is right call the manufacturer directly and ask if their tuner works on the 2017s. If yes have them put it in writing that they will refund cost of tuner plus shipping if it doesn't work.
  • 3 weeks later...
Bought a diablosport intune i2030 i2 used off a guy for my 16' sierra 5.3 6 speed auto, works great. Deleted AFM and put their standard tune on, truck drives like a dream and takes like 3 minutes to return the tune back to stock.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
